Fox P/S flow reducer adapters
Old Mar 7, 2012 | 05:18 PM
06colorado's Avatar
Default Fox P/S flow reducer adapters
Iv search but havnt found anything particular for my swap. Im running the truck ly5 motor in my 88 mustang and iv found that this http://www.jegs.com/i/Billet+Special...P1300/10002/-1 is what the older gen 3 motor were using on there pumps.
also http://www.jegs.com/i/Russell/799/648060/10002/-1 and http://www.jegs.com/i/Russell/799/648070/10002/-1
to adapt to the rack, Can anyone confirm this before i spend some cash thanks
Old Mar 7, 2012 | 08:01 PM
zipster's Avatar
I think the billet flow valve will work. It has the correct output. The metric adapters you have listed are the wrong ones. The seal should be on the threaded end by the hex.
I am going with this flow valve http://www.speedwaymotors.com/Mustan...isplayId=24682
I went to the hydraulic supply store (Parker) and got two adapters they are #6 JIC on one end and are 14mm x 1.5 and 16mm 1.5 on the other ends.
I remembered Speedway has these http://www.speedwaymotors.com/1982-8...DisplayId=5852
Old Mar 7, 2012 | 09:25 PM
06colorado's Avatar
Thanks, do you know if the 88 t-bird kit will work on the fox rack?
Old Mar 7, 2012 | 09:34 PM
zipster's Avatar
Yes the 88 t-bird rack is the exact same.
