Connection of the PCV port on passenger side valve cover
The PCV port for fresh air is usually routed to a port on the Throttle Body or the intake tube post MAF.. It is after the MAF so that I can be part of the Metered Air being monitor going into the engine.
The PCV vapor return port is usually routed from the valley cover port to a port behind the Throttle body on the Intake Manifold.
You should be able to find a few post on this if you research for it on this forum (and others).
BC
BC
