Fan Question
Old Mar 8, 2012 | 03:56 PM
80bu's Avatar
Default Fan Question
I have a issue with one fan not coming on. I have a new fan motor, relay and fuse. I have discoved I have power coming out of the fuse block to the relay with a test light. The blue wire from the computer is going to the relay and when I put the test light in the blue wire at the relay the fan kicks on, as soon as I take the test light away the fan stops. These are ls1 fans also. I have been driving this thing for a year with no problems. Jesse at wait4me did my harness rework.
Old Mar 8, 2012 | 04:02 PM
Your test light is grounding the circuit. Check your grounds.
Old Mar 8, 2012 | 04:40 PM
gMAG's Avatar
Yes, verify the ground on the non-working fan.
Old Mar 8, 2012 | 06:58 PM
80bu's Avatar
I switched the plug that went to the non working fan to the working fan and it worked just fine. So how could it be a ground if it works on the other fan?
Old Mar 8, 2012 | 07:10 PM
67Skylark's Avatar
Sounds like the ground for the coil of the relay may be bad.
Old Mar 8, 2012 | 07:11 PM
LS1MCSS's Avatar
Your pcm is putting out a ground signal. Is that how you have the wiring setup?
Old Mar 8, 2012 | 08:17 PM
80bu's Avatar
I use the fan signal from the pcm to the relay. How do I fix this issue?
Old Mar 8, 2012 | 08:29 PM
psiconversion's Avatar
LS1Tech Sponsor
I'll assume this is a Gen III setup. Disconnect the relay and check continuity on the fan trigger wire (whatever color is going back to the PCM, I guess blue in your case) to the PCM Blue connector, position 42. If you have continuity, then either the relay is bad (which I doubt since you said it worked when the test light was hooked up), or the PCM is not telling the fan to come on. If there is no continuity then the wire is broken.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 9, 2012 | 09:42 PM
80bu's Avatar
I have a new relay, I am going to dig thru the harness and check the blue wire from the pcm to relay. What happends if it's not getting a signal from the pcm? How do I fix this issue?
Old Mar 9, 2012 | 10:39 PM
LS1MCSS's Avatar
Which relay terminal is it connected to? Better yet, how are all the wires connected at the relay? We can't really tell you what's wrong without knowing more about the way you have the wires connected.
Old Mar 10, 2012 | 09:44 AM
Ok, this setup worked fine for a year, right? You changed the motor, relay, and fuse because a fan stopped working. One fan still turns on properly, right? And when you change your plugs around, the new fan comes on, right? I'd take a look at the plug on the nonworking fan.
Old Mar 17, 2012 | 10:18 AM
80bu's Avatar
I have replaced the connector on the non working fan. I have the blue wire to the relay from the pcm. I have a hot wire to the relay from the fuse block that get its power from the battery. I have checked the wire and it is not broken. Can I take another wire from the pcm or can I control the fans another way?
Old Mar 17, 2012 | 11:16 AM
G-Body's Avatar
sawzall wielding director
From some of your other posts it looks like you may be running a truck 5.3L?
1. Is it a truck PCM? What year?
2. Did the fans ever work or has this been a problem from the start?
3. What pcm pin does the blue wire go to? (Most likely blue connector pin 42 or red connector pin 33).
Old Mar 17, 2012 | 12:07 PM
80bu's Avatar
Its a camaro 2002 pcm
The fans have always worked, I noticed I had a problem when i was blowing a fuse when the fans came on ,So i put two new fan motors and connectors and now only one fan works.
The blue wire goes to pin 42 blue connector.
Old Mar 17, 2012 | 06:42 PM
Indyjc's Avatar
I'm having the same problem. I believe my issue is a broken wire or a bad pcm. I've been waiting for a hot day to see if it over heats, but so far it has stayed at 180. Good luck.
Old Apr 1, 2012 | 05:03 PM
all juiced up's Avatar
do i hook the computer negative to the fan negative and the key on to my 30 amp relay
Old Apr 1, 2012 | 07:08 PM
mantycarguy's Avatar
Wire it this way. pin 30 on relay to battery +, pin 87 on relay to fan +, pin 85 on relay to key switched +, and pin 86 on relay to pcm dark blue wire.
Old Apr 2, 2012 | 11:54 AM
G-Body's Avatar
Try popping the connector off the PCM and ground the blue wire that goes to pin 42 at the pcm connector with the ignition on. If the fans turn on the problem is in the PCM, if they don`t turn on then its in the fan, the connectors or the relay.
