Foxbody swap w/ psi harness come inside. Installation q's.
Just ordered my harness from psi conversion. I've already went through and read the instalation guide and it very straight forward, what I'm wonder is those who have already installed this harness in their mustang where and how did you tie the psi harness inside the car/route it/etc. just trying to get a basis of exactly where and what I need to do to get the car wired.
I have my harness ran through the A/C drain hole on the lower passenger side with the computer mounted where the stock one was just a little higher.
I can get pics for u tomorrow if u would like.
Here is the ignition switch wiring. If you want to find a wire to tap off of, just put 12v on the 12ga yellow wire that powers up the ign switch. Then turn the key to wherever you want power to be sent out to whatever acc you are wanting to run. But any 12ga wire off the ign sw is going to be a power wire. Do not try to tap off one of the 18ga wires.
What I'm doing on my swap is just removing anything I'm not using. So the blk/lt grn wire will power up all my fuses. Then I will use red/lt grn wire to power up my main relay to run the engine.
