L59 (5.3 flex fuel) question
. There are also not any drawbacks that I can think of. Running a tank of e85 every once in a while is a good way to clean the fuel system and injectors though, just watch out cause it tends to plug up a fuel filter a lot faster than a car that just runs plain gas.
. There are also not any drawbacks that I can think of. Running a tank of e85 every once in a while is a good way to clean the fuel system and injectors though, just watch out cause it tends to plug up a fuel filter a lot faster than a car that just runs plain gas.IIR its the 2005+ motors that don't have the FCS, the PCM has to have a working fuel level sensor, and the capacity of the fuel tank programmed into the PCM to run e85 with out the FCS.
there's a bunch of threads on flex fuel here and on hptuners if you wanna dig.
