4L60E transmission question
Old Apr 24, 2012 | 09:51 PM
veltboy618's Avatar
Originally Posted by the_merv
Ive seen them side by side and the shafts themselves were different..mustve been something else instead of a 4L60E..
Main question here for the OP is the car going to be EFI or Carb?
Im going to keep it FI
Old Apr 24, 2012 | 10:17 PM
the_merv's Avatar
Veteran: Air Force
Ah ok. The reason I ask that is in response to the $400 Trans box.
For $400 you can have a Harness, PCM, and the credits to tune it.
Then again that is if you do all the work and wire it, and have the tuning software.
Old May 14, 2012 | 04:11 PM
veltboy618's Avatar
I had the day off so I was running around looking for transmissions & I found a couple of them. One was a 2WD from a Tahoe with a 4.8 & the other was in a 2WD 2002 Tahoe with a 5.3 in it. Will the 5.3 trans work fine with mt 2002 Sierra engine? What about a tranny that came behind a 4.8? Are they the same & will that one work?
Old Mar 3, 2013 | 10:04 PM
heyguy's Avatar
this post help you deal with all problem of 4L60E Transmission
Symptoms Of The Car When 4l60e Transmission Not Working Properly
read it here
http://www.4l60etransmission.org/category/perfectly/
Old Sep 28, 2023 | 05:50 AM
scott1989's Avatar
Originally Posted by Jeremy@RPMTransmissions
A 4L60e from a 98-02 V8 f-body, 04-06 GTO, 99-07 GM 2WD V8 1500 trucks and SUVs will work. Vans are iffy. You have to make sure it had a 5.3 V8. They used a lot of 5.7 vortec motors in the Vans till the late 2000s.
If you decide you would like a built 4L60e let me know. I'll work up a quote for you.
I have a question. I’m doing a 03 5.3 carb swap. With a 4l60e transmission. What wires can I get rid of from the harness that is going to the 5.3 pcm. I got the motor and trans with a complete harness and pcm but it went into vats mode which is why I’m doing a carb swap
Old Sep 28, 2023 | 11:58 AM
Jeremy hasn't been here in over 4 years.
Old Oct 3, 2023 | 09:46 PM
the_merv's Avatar
Veteran: Air Force
A very simple tune will turn off the VATS stuff but if you don't know that by now given in the last 20 years the tools have been out there to turn it off yea the computer stuff isn't for you.
