Cooling fans for 68 camaro
Old 03-23-2012, 05:15 PM
firstgenguy's Avatar
Default Cooling fans for 68 camaro
Looking for ideas on cooling fans. Ls1 in a 68 camaro. I have a 2 row aluminum radiator in it now. Wanted to use stock LS1 fans or something similar.
Old 03-23-2012, 05:34 PM
rp0029's Avatar
Lincoln Mark 8. Can't go wrong.
Old 03-23-2012, 07:04 PM
Are you talking about the big single fan? would you happen to have any pics of the lincoln fans installed?
Old 03-23-2012, 07:12 PM
gMAG's Avatar
Here's what I did...post #18 & #19- stock LS1 fans.
I don't know if the dimensions of your radiator and my radiator are the same...you'll need to verify that your rad is large enough to accomodate the two fans.
You'll see that the upper plastic fan assembly is attached with alum L channel.
The bottom of the fan assembly is also attached with L channel.
If you need more pics, I can get them to you.
https://ls1tech.com/forums/conversio...l#post14341550
