Turbo 5.3 LSX Nova (Problem)
mp70 turbo
megasquirt
z06 cam
Car is blowing smoke from breather hoses on driver and passenger side, and under boost blowing oil out. Problem got worse throughout the day after a couple of pulls, the exhaust is now blowing white smoke out the back after a pull, but after sitting for an hour I cranked it up again and it was not smoking. I think I am getting excessive oil through the turbo and also through my breather tubes under boost.
Plz help if you can. I am worried that I may have a blown head gasket, and extreme blow by
Umm... that's basically the definition of blow by. The white smoke out the tailpipe could be coolant but I doubt it with your blow by problem. More likely that's also oil being blown out your exhaust, also a possibility is you now have too much pressure in your crankcase for your turbo to drain and it could be pushing oil past the seal into the turbine housing.
