Think I can mount this A/C compressor with 2 bolts?
I want to mount this A/C compressor in the stock low-mount location, however, my motor mount adapter plates and subframe interfere with the rear upper and rear lower compressor mounts. If I cut those mounts off the compressor, it looks like it will fit fine. So the question is... can I safely mount this compressor to the compressor bracket using only the front two bolts located on either side of the pulley?
I know a lot of GM compressors are mounted with 3 bolts - 2 by the pulley and 1 in the rear of the compressor, but I've never seen one mounted with just two bolts.
What do you think, and why?
BTW, this compressor is from a 2012 Express van.
I forgot about belt tension. It is a stretch-to-fit belt with no tensioner. On the bright side, the two mounting points are very close to the pulley, so the belt will have very little leverage working against the bolts.
I wish there was a way to anchor down the back of the compressor.
I am using the same compressor but from a Silverado. I plan to run the front two and the upper rear, cutting off the lower rear due to interference with my frame. I am using the OEM bracket which has a tensioner incorporated (not stretch-to-fit).
Here is the OEM silverado bracket which I notched to fit around my 1/2" setback Dougs adapeters:
![](http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap259.JPG)
![](http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap339.JPG)
Here's what it looks like almost mounted. I haven't trimmed the lower rear mounting boss off the compressor yet so it doesn't quite fit in my frame, but you get the idea.
![](http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap261.JPG)
![](http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap344.JPG)
I think running just two bolts may be asking for trouble. Are you running into interference issues?
Clint,
What welder did you use to weld your frame notches? I just got my Millermatic 211MPV, I will be doing the pass. notch too. Any final wword/plans on you engine yet?
thanks,
Jim
thanks,
Jim
