Clutch pedal bracket for ls1 swap into a 69 Camaro
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
So I know there is a bracket you can make to use your stock clutch pedal with the clutch master cylinder that came from the donor car. I keep seeing this drawing floating all over the internet but have yet to find one that I can actually read.
Does anyone have a clearer version of this drawing or can tell me what the dimensions are?
![](http://i133.photobucket.com/albums/q75/f150x05/pedaldrawing69.jpg)
http://www.hotrodlane.cc/New%20LS%20....html#installs. Then click on S&P installs a LS-2 into a '69 Camaro.
I just cut the end of the MC rod off then cut about 2 inches off the rod and welded it back together. then drilled a hole in the brake pedal to that the rod actuates in a linear motion...seems to work great so far.
