5.3 with old 5 speed
Old Apr 22, 2012 | 08:38 PM
domchevelle's Avatar
Default 5.3 with old 5 speed
Hi ,i need informations,i have 98 silverado 2wd with tierd 4.3 and 5 speeds transmission.i want to install 5.3 in it and keep my original transmission, what kind of flayweel setup i need to install in it?Tank's
Dominic
Old Apr 22, 2012 | 08:44 PM
thesource's Avatar
Given that particular year used an internal slave cylinder much like the F body did, I would bet a LS1 style flywheel/clutch setup will bolt right up and work fine. You might need to shim the slave though.
Old Apr 22, 2012 | 09:14 PM
tank's for your reply,but the LS motor is .400 shorter then old sbc?
Old Apr 23, 2012 | 12:01 AM
i r teh noobz's Avatar
I used the Sachs 1050 flywheel for an 06 Silverado to mate my TKO to my 5.3.
Old Apr 23, 2012 | 07:06 AM
garys 68's Avatar
Depends on the bell housing. Does it currently have a 168 tooth flywheel?
Check out this for flywheel/clutch options.
https://ls1tech.com/forums/conversio...-ls-motor.html
