Can any E38 DBW pedals be interchanged with one another
Old Apr 27, 2012 | 02:03 AM
Hans Grüber's Avatar
Question Can any E38 DBW pedals be interchanged with one another
I have a 2010 Camaro E38. Can I use a Corvette DBW pedal with this or any other DBW pedal as long as the vehicle also has an E38? Is a reflash required?
I have searched but can't find a clear answer.
Old Apr 27, 2012 | 02:49 AM
LSxChevelle's Avatar
Interested as well...
Old Apr 27, 2012 | 12:13 PM
1989GTA's Avatar
I plan on using one out of a later Corvette. I think 2006 and up. Maybe a year later. I saw one on EFI Connections and the pin-out/ wiring colors were identical to my E38 harness. Mine came off a 2009 Escalade. So that is the one I plan on using for my 1965 Buick Skylark Conversion. I don't see why a reflash would be necessary if you are using the correct DBW accelerator pedal.
Edit: I finally found one. Here is the link. http://secure.ultracart.com/catalog/.../ACC-1007.html
Old Apr 27, 2012 | 10:35 PM
V8Rumble's Avatar
I don't have a definite answer (yet!), but I'm actively giving it a try... The engine I'm using in my swap is a 2008 L92 (originally intended for an Escalade), so I called around & found a service writer at one of the local dealerships who was willing to take a couple minutes & look up the pinouts/voltages, etc. for me. From what we could tell, the specs were identical between the 2008 Escalade pedal & the 2008 (maybe it was 2009??) Corvette pedal. I currently have the Corvette pedal installed in my car (what the hell, it seems like a safe bet!), & I'm hoping to have it all running within the next couple of months.
Believe me, I'll post up & let everyone know whether it works or not...
Old Apr 28, 2012 | 01:43 PM
So the Escalade uses an E38 and not an E67?
Old Apr 28, 2012 | 02:37 PM
Project GatTagO's Avatar
2010 SUVs with the 6.2L engines used the E38:
http://archives.media.gm.com/us/powe..._PWT_L94_n.doc
The E67 in the GMPP kits is supposedly from the CTSV.
Andrew
Old May 3, 2012 | 01:51 PM
So any DBW pedals from an E67 or E38 are directly interchangeable?
