LT1 to LS1
Old Mar 28, 2004 | 10:47 PM
ponyeaterz28's Avatar
Default LT1 to LS1
converting 97 lt1 to 2000 ls1. Can't use 97 abs pump, there's no room because altenator is on opposite side from lt1. have a 2000 abs pump & bracket that fits perfect, but plugs are totally different. does anyone know what to do at this point.
Old Mar 29, 2004 | 12:50 PM
crainholio's Avatar
ABS pump??? Only thing pumping ABS that I know of is your foot on the brake pedal...maybe I'm missing something?
Old Mar 29, 2004 | 04:09 PM
Wrong choice of words. I meant ABS module. Surely someone has run into this problem besides me. I,m at a standstill.
Old Apr 2, 2004 | 09:47 PM
cgworth's Avatar
there are basicly 2 wiring harness's under the hood 1 for the engine and 1 for the lights, fusebox, abs, etc and you will need to swap both
Old Apr 4, 2004 | 10:26 AM
does anyone have GM part numbers for the two wiring harnesses I need or a better source than GM?
