LM7 into '86 C10
Old Apr 5, 2013 | 11:50 PM
  #61
Nick_R_23's Avatar
Fuel lines ran
Throttle cable bracket came in today. This was meant for an Edelbrock, but it seems like a pretty good angle on the TV cable. Is this right?
Old Apr 6, 2013 | 10:03 PM
  #62
Nick_R_23's Avatar
Anyone have input on the TV cable?
Old Apr 6, 2013 | 11:16 PM
  #63
71403's Avatar
I'd make it a straight line pull, looks like you have the room
Old Apr 7, 2013 | 07:55 AM
  #64
Moter's Avatar
No it is not correct. It needs to be a straight shot and properly adjusted the first time you drive it. If not you will burn up the trans.
Old Apr 13, 2013 | 12:22 AM
  #65
Nick_R_23's Avatar
Sorry about the delay between posts, I switched jobs and haven't had as much time to work on this.
Here is my solution to the TV cable bracket. I took some measurements and determined the hole needed to move over exactly 1 inch. Instead of cutting and rewelding the bracket, I flattened out the other Edelbrock TV bracket and welded it to the back of this one. One, it reduced the amount of fab and welding needed to get the cutout in the proper position, and two, it added some strength to the bracket.
Old Apr 13, 2013 | 02:03 AM
  #66
Nick_R_23's Avatar
Painted
And mounted. Much better!
Also re-bent the vacuum booster line to clear the bracket and throttle cable.
Old Nov 17, 2013 | 09:44 PM
  #67
vern6.0's Avatar
Hey do u have any extras laying around. I mean those steam bypass pipes u made to go into the heater hose? If so I like to buy one thru paypal if possible
