64 Chevelle turbo project
Finally got the turbo project done (almost). It was a heads/cam project (approx 480 hp). I put about 800 miles on last year after I got it driveable, then got bored. Started it up today, cant drive it till I get some more gas to weld in the BOV.
1964 Chevelle
LS1 (approx 9.8:1 comp)
T56
12 bolt w/ 3.42 gears
E85
Aeromotive FPR (44 psi base pressure)
-8 fuel supply
-6 return
2 intank Walbro 255 ( 2nd pump on 5psi Hobbs switch)
SD 80 injectors
Comp Cam 227/223 .610/.614 115 LSA
truck heads w/ Lunati springs (home ported)
truck manifolds
2.5" hot side
Precision 39mm waste gate (12 psi spring, for now)
TC 78 w/ 1.15 A/R
3.5" downpipe to full 2.5" exhaust
LS9 head gaskets
3" cold side
Ebay 31x14x3 intercooler
LS7 clutch (for now, previously installed will change out later)
![](http://i391.photobucket.com/albums/oo356/gearhead74/Chevelle/turbo42.jpg)
![](http://i391.photobucket.com/albums/oo356/gearhead74/Chevelle/turbo41.jpg)
![](http://i391.photobucket.com/albums/oo356/gearhead74/Chevelle/turbo21.jpg)
![](http://i391.photobucket.com/albums/oo356/gearhead74/Chevelle/turbo.jpg)
![](http://i391.photobucket.com/albums/oo356/gearhead74/Chevelle/intercooler.jpg)
1964 Chevelle
T56
E85
-8 fuel supply
-6 return
SD 80 injectors
truck manifolds
2.5" hot side
TC 78 w/ 1.15 A/R
LS9 head gaskets
3" cold side
![](http://i391.photobucket.com/albums/oo356/gearhead74/Chevelle/intercooler2.jpg)
I am lovin this build....I have a 64 with an LQ4 and TH400 that I want to turbo....Your build is answering alot of my fitment questions.
I DD mine now though so I am waiting till I have another way to get to work.
Keep posting.....More pics if you can....I would love to see more detailed pics of the hotside from underneath.
Thanks.
Thanks.
Thanks.
Thanks.
