LS2 s10 project
Old Jun 24, 2013 | 01:55 PM
  #41
TXsilverado's Avatar
the neighbors got a sneek preview yesterday evening
Old Jun 24, 2013 | 04:49 PM
  #42
69Lsx6.0's Avatar
Nasty!
Love the look with the cowl hood and Pro-Stars! That things gonna haul ***!
  #43
I hope so. i just want to drive it around the block at this point.
Old Jun 24, 2013 | 04:51 PM
  #44
69Lsx6.0's Avatar
I hear ya. I just got the Camaro running and I feel the same way.
Old Jun 25, 2013 | 02:22 PM
  #45
8ty8 LS1's Avatar
i may have missed it, but with the H3 pan, did you have to notch the cross member? also, is there a picture of the oil pan to cross member clearance?
Old Jun 25, 2013 | 02:24 PM
  #46
no cutting required. the pan hangs about 1/2" below the cross member.
Old Jun 25, 2013 | 02:46 PM
  #47
8ty8 LS1's Avatar
thanks for the quick reply!!! i'm thinking about ditching the dry sump system for my ls7 and converting to wet sump. so i'm just now researching the oil pan stuff
Old Oct 9, 2013 | 06:19 PM
  #48
this turd is still in progress. getting close(ish) though. lots of stuff finished and installed now.
installed spring sliders
QA1 coil overs installed up front
transmission lines/cooler finished
throttle cable/linkage is done
fuel cell is strapped down
battery is relocated to the bed next to the fuel cell
tubular upper and lower c-arms
tint
and a bunch of dumb misc **** that is driving me nuts. tps sensor, evap junk/fittings...im about sick and ******* tired of fittings
still needs brake lines, driveshaft and 8.8 rear end. also needs TCU to be hooked up and a fender well installed.
oh and that horrible looking booster needs some paint.
the cleaner doesnt sit as high anymore.
Old Oct 9, 2013 | 09:34 PM
  #49
68nou1's Avatar
That thing sounds awsome!! It makes me want to do a swap alone.
Old Oct 9, 2013 | 11:20 PM
  #50
skinumback's Avatar
tint
Please look for a 2wd 8.5 s10 rear rather than a 8.8! Nice build don't jack it up with a ford rear now! Thanks! ~
Old Oct 10, 2013 | 12:30 AM
  #51
bradw18's Avatar
nice build man. I got a 5.3 in a 91 s10 and used a bunch of the same parts as you except im fuel injected. and I have a few stages also. what gears you gonna run? im doing 3k at about 58 mph. I hate it!!!!! I have 373s
Old Oct 10, 2013 | 09:16 AM
  #52
3k at 58mph? what transmission are you runing? i have an 8.8 rear end sitting in the corner waiting for some mods. 4.10 gears behind a 4l60e wont be bad. should put me right around 2200 rpm at 70mph.
Old Oct 10, 2013 | 09:20 AM
  #53
8.8 is stronger and cheaper. i searched for an 8.5 for about 2 months. couldnt find one...and the ones i saw that sold were 4-500. then id need to buy a posi and gears for it. i got my 8.8 for 400 with 4.10 gears, a posi, disk brakes and it's stronger. there is no changing my mind at this point. the wheels are already offset for a cut 8.8 rear end. i had to add 1" spacers to the 7.5 to get these wheels to mount. otherwise they were stuffed into the frame.
Old Oct 10, 2013 | 02:54 PM
  #54
bradw18's Avatar
th350 plans are a 6 speed later on in life
Old Nov 25, 2013 | 12:15 PM
  #55
the 8.8 is in. narrowed, welded tubes, new races, bearings adn seals. driveshaft is built. 3150 all the way around. backed it out of my garage and back into the garage about 15 times now still need to install the transmission controller, but i couldnt resist.
here is the final stance after some qa1 coilovers up front and the 8.8/slider install out back.
and a video of idle/rev....then me getting a little excited
for some reason i can't get into the mood to installe the transmission controller.
Old Nov 27, 2013 | 01:30 PM
  #56
BadWolf's Avatar
this makes me want to build an S-10. it sucks cause id have to have an extended cab
Old Nov 27, 2013 | 01:34 PM
  #57
1st gen ecsb s10 probably weighs less than a 2nd gen rcsb.
Old Nov 28, 2013 | 10:58 PM
  #58
BadWolf's Avatar
good to know!
Old Jan 9, 2014 | 10:29 PM
  #59
crazy3rdgen's Avatar
You have me drooling over here...
Old Jan 10, 2014 | 09:15 AM
  #60
thanks. wish it was finished already. i went under the knife for some back surgery and havent touched the truck at all other than pulling off the carb and selling it. going with a larger carb if i can scratch the funds together. the Dr released me to start light work in the gym in 2 more weeks, so i figure that means i can do light work on the truck!
