oil pan question on 5.3 swap
Old 06-07-2012, 10:11 PM
topspeed02's Avatar
Default oil pan question on 5.3 swap
Hey guys I was working on my motor today and pulled off my old pan. The motor is from a 01 Chevy Silverado. It had this sensor in the oil pan but my GM muscle/H3 pan does not have provisions for this sensor. Can someone please point me in the right direction.....
Old 06-07-2012, 10:16 PM
Bo185's Avatar
Its the oil level sensor its not need just remove the wires form harness and delete it in the PCM.
Old 06-07-2012, 10:20 PM
topspeed02's Avatar
Awesome I kinda figured that's what it was for.... So the newer motors dont have any level sensor anymore?
Old 06-08-2012, 09:40 AM
cruisin'73's Avatar
Default Sensor Plug
FYI, if you want to get rid of that sensor body, you can replace it with a M20-1.5 oil pan plug. I am running a carb on my conversion so obviously not using the level sensor. I was able to get the a hex head plug at my local parts store for $4.
Old 06-08-2012, 05:06 PM
sweetk30's Avatar
my plug i did . modifyed for 1/8th pipe thread oil temp sender.
yep about 4 bucks and included gasket also .
drilled / tapped out and last overdrilled 1/2 way down for oil on sensor room.
Attached Thumbnails oil pan question on 5.3 swap-0601121341a.jpg   oil pan question on 5.3 swap-0601121341b.jpg   oil pan question on 5.3 swap-0601121342a.jpg
Quick Reply: oil pan question on 5.3 swap
