Fuel pump relay control lsxfox
Does this mean the relay for the fuel pump under the driver seat? What wire does it tap into or replace I'm confused and need help. My friends left me high and dry for Friday night runs, so can someone please walk me through this
A buddy who has a ls1 turbo fox told me to wire it into the pink w/ blk stripe wire that is 1 of the 3 in the trunk area. Does this sound right?
Orange/ light blue is 12v constant
Pink/black is pump power
red/black is 12v ignition from the inertia switch
tan/light green is ground from the ECM to complete the circuit powering the pump.
Here is what you are going to do to make it work.
Take the fuel pump power enable from the GM PCM to the rear of the car, cut and splice into the RED wire on the inertia switch
Take and cut the Tan/light green wire from the ECM and put it to ground.
Pump will power when the GM PCM tells it to.
Hope this helps.
EDIT: To maintain the safety factor of the factory inertia switch YOU MUST CUT THE RED WIRE and splice the Power from the Fuel Pump power from the GM PCM
These are the colors of the wires at the fuel pump relay under the seat.
The red/blk wire has been cut and tied into the pink/blk wire and the solid red wire is left the same.
How can I wire my fuel pump relay control wire into the group of wires under the driver seat and make this run with the wires being jerry rigged like they are, I don't care if the inertia switch works or not
Then take the tan/light green wire under the seat and cut it from the relay plug and just ground it out? Is this right?
