A/C & Cruize wiring help needed
I plan to eventually install air conditioning into our 1966 C10, but it will probably be an under dash unit and I plan to use the stock 5.3L A/C Compressor. There are are several wires for air conditioning built into the harness. Are any of these wires worth keeping if I plan to use an under dash unit or should I pull them out?
I also would like to use cruise control. What wiring would be necessary to keep?
Thank you,
Kevin C
On the DBW cruise control, chec\k out LT1swap.com.
THank you,
Kevin C
I just hooked those break out cables into this.
http://www.dakotadigital.com/index.c...prod/prd49.htm
It works perfect. Good luck
The 5 page color wiring diagram helps too. You can find that here on the diagrams/pinout thread.
Problem is, I cant seem to find out which vehicles have fixed vs variable displacement compressors on LS motors.
05 L59 Classic auto air, saneden compressor, no AC request (serial data), no bogging either.
Both DBW, maybe cable is different.
Im thinking prob a bad compressor.... Somehow
