71 El Camino 6.0/4L60E
This one's my wife's daily for her B-day picked up a 6.0/4L60E with harness and truck acc. My plans are to keep it simple low budget. Maybe header the biggest problem decision I'm having is which way to go with fuel pump.Wiring harness gone through and pcm reprogrammed, and f-body oil pan old motor to come out tonight. Needs new gauges and a roof.
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1387.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1389.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1382.jpg)
LS1Tech Sponsor
http://shop.brutespeed.com/Kooks-645...450-S-0711.htm
The Kooks headers will fit your El Camino. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
well as f%4*d up as this day was I still got the old motor and the new around back looks like some frame nothing will ease things along. would kooks but there not in the budget .
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1439.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1441.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1440.jpg)
Try Dynatech or Schoenfeld for lower prices.
A lot of times, 68-72 A body and 2nd gen F body headers will interchange. The tight spot I found the one time I had a set of each car for a BBC to compare was the back lower control arm mount. -and the clutch linkage-
LS1Tech Sponsor
Yeah, the Kooks are more expensive but they have 1-7/8 tubes and 3/8 flanges. Dirty Dingo makes engine mounts for LS conversions in case you need mounts. You're going to have a nice ride when it's done! Bob
__________________
well it runs and trans rolls goes threw the gears. still some cleaning up to do I hope this was the hard part getting it in and running. Thinking Stewart Warner or So-Cal for instrument upgrade. what do think?
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1464.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1421.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1444.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1513.jpg)
![](http://i1218.photobucket.com/albums/dd417/seancarole1/100_1514.jpg)
Just ordered my Gauges. Went with Stewart Warner Wings, electrical, white face. Gettin em from Speedway Motors. New fuel pump and sending unit should be here this week for the Roadmaster fuel cell. I got it started up, but am having issues with wiring. I think it relates back to an old problem in the ignition wiring. While waiting on parts, It's time to start stripping. The leather off the rusty *** roof. Which is worse, working on the wiring or stripping the roof? Taking donations for beer. X(
I put stewart warners on my 72 El Co. They look great, but the style I wanted required 240 ohm senders. They didn't have a 90 ohm sender version of the fuel gauge. I ended up buying a replacement gas tank to retrofit it to accommodate a 240 ohm sender. After that didn't work out because the fuel gauge reading was off, I ended up buying a Rick's tank and installed a universal 240 ohm sender with an in tank pump.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Just found some last week on e-bay for $200 for my Nova that are Stainless Steel so more and more compaines are making stuff for us LS swap guys and the price will keep coming down and down.
Said these will all so work for a El Camino you might give them a try.
http://www.ebay.com/itm/180912843354...84.m1436.l2649
