Run/Crank and Power/Train Relay Size ?
I am building my own fuse block for my l92 engine installation. Right now the relays I have on hand are 50amps each. Will 50 amps be enough to handle the Run/Crank? Will 50 amps be enough to handle the Power/Train relay? I am using a modified factory harness.
