ignition feed problems
Old Jun 26, 2012 | 12:34 PM
haulass350's Avatar
Exclamation ignition feed problems
i had two wires that i had to transfer to my new 2002 pcm from my old 97 pcm
specifically these two
02 blue connector:
#19 repin with 97 black conn. #18 PINK Ignition Feed
#75 repin with 97 blue #4 PINK Ignition Feed
looking at the gm service site it says that the first will cause a no change and the second will cause no crank.
well when i was removing my old harness i fucked up and cut them and i dont know where they go now.
sooo can i hook them to a hot in run source and fix my problem?
Old Jun 26, 2012 | 07:13 PM
haulass350's Avatar
nvm figured it out
