VSS questions/problem
Old Jun 26, 2012 | 10:03 PM
Crazier's Avatar
Default VSS questions/problem
The swap I am doing uses a Corvair trans and diff.
The Corvair mechanical spedo runs off the drivers side front axle.
I haven't been able to get the wheels apart yet, some pretty bad rust issues. BUT I don't think there is room in there for the VSS sender even if the capacity to hook it up existed, and I kinda doubt that anyway.
Is there a VSS that will go between the spedo cable and the gauge? Or some other way to get a VSS signal?
Any proven, or hair brained ideas are appreciated.
Old Jun 26, 2012 | 10:57 PM
bczee's Avatar
you can try and look into the Cable-X box..
BC
Old Jun 26, 2012 | 11:34 PM
Crazier's Avatar
http://www.dakotadigital.com/index.c...prd_zm_109.gif
This looks like it would work. but if I understand it correctly I would need the wider end to attach to the input side and the narrow end to run to my speedo.
I have been looking at other threads and I think thats backward of how they normally run. I guess I just need to call them tomorrow. Maybe they can run either way.
Old Jun 27, 2012 | 12:21 AM
71403's Avatar
That's your standard inline VSS, there are a lot of flavors of thread/drive adapters for them. Drive off front wheel sounds a lot like early VW did one on a dune buggy (VW bug) aftermarket speedo install.
JTR has/had a driveshaft mounted VSS wheel/pickup setup.
Retrofit a ABS ring to one of your CV joints if there's somewhere to mount a pickup?
Old Jun 27, 2012 | 12:36 AM
Crazier's Avatar
Ya, the Corvair set up is used in my Valkyrie kit car, and GM definitely copied a lot of the VW set up (after considerable improvement) on the Corvair.
I dont have a CV joint I don't think.
Old Jun 27, 2012 | 06:17 AM
garys 68's Avatar
The dakota digital should work if you can getr the adapters.
If not I'm using a 2 wire sensor from these guys. It uses the reverse gear in my T10 as a reluctor.
http://www.magsensors.com/
Old Jul 15, 2012 | 11:05 PM
Crazier's Avatar
Ok, so the computer rewire guy is bugging me for my rear tire size and rear gear ratio. says I need it if I want to keep the VSS
He also says that he eliminate4s the VSS all the time on sand rails
My trans has no capacity for a VSS sensor, and the speedo runs off the drivers side front tire, so what effect could rear tire size and gear ratio have on a VSS if it wasnt running off the rear or the trans?
and is he full of crap about not needing a vss? is thre something different about how a sand rail is used makeing them able to get away without the VSS?
Old Jul 16, 2012 | 03:12 AM
garys 68's Avatar
You'll find without vss the engine will stall with clutch depessed coasting down from hiway speeds. Maybe his sandrails dont do a lot of hiway driving. Your tuner is thinking you're running the vss off the trans. Good news is the ecu doesnt care how fast you're going to avoid this. The dakota digital vss will fix this problem without being correctly calibrated. As it sits, mine is reading 3-4 mph when I'm doing 60.
On a side note, if you have it over calibrated, the speed limiter will kick in at around 135mph.
Old Jul 16, 2012 | 09:58 AM
Crazier's Avatar
so I should jsut have him leave it totaly alone and hook a sensor up to it?
Old Jul 16, 2012 | 10:06 AM
bczee's Avatar
I run my Chevelle without an VSS input to the PCM... I don't have any stalling issue without it on mine.!?!
If you could add the VSS input, it would be beneficial to assist with driviablity and as noted, on stopping or slowing down. (if you have stalling issue). If you have an electronically control Transmission, it would be best to have it. But with a manual..yo can get away without it.(for most).
BC
Old Jul 16, 2012 | 10:18 AM
garys 68's Avatar
DBW or cable? I've had 2 DBW motors, both had stalling. Very reproducible. Both tuners that did my ecus said they've seen the same thing.
Crazier
You can leave it as is if you dont want DBW cruise control.
BC
Old Jul 16, 2012 | 10:27 AM
bczee's Avatar
My chevelle is DBC....
Old Jul 16, 2012 | 10:55 AM
garys 68's Avatar
Yeah, that might be the difference. My 02 LQ9 with DBW had a 411 ecu, probably the same as yours, stalled consistently when clutch was depressed and coasting from around 60 mph to a stop almost every time.
Tried the same with an 05 L59 DBW when I was adding a VSS to a T10. I was able to do the same with that one too.
ECUs were done by different tuners that said they've seen the same thing.
Not sure why an IAC would be better than a DBW TB at controlling idle without VSS though.
Crazier has DBW, better to leave it in and spend $60 for a DD VSS than having to pull the harness and wire/repin the VSS. Ask me how I know.
