2003 LQ4 with a 4l60e
Old Jul 2, 2012 | 12:17 PM
Cecil07's Avatar
Default 2003 LQ4 with a 4l60e
Hey guys... first off let me appolgise if this question seems pretty basic... I have been searching and searching and I'm sure the answer is starring me in the face but I'm having trouble finding a clear answer.. I wanna use a 2001 2wd 4l60e transmission with my 2003 LQ4. I've pulled the flex plate with spacer off. Now Do I just need a basic ls1 or 5.3 flexplate to make this work...?... there is like 10 choices to pick from on ebay which is probably my best bet... any info or if someone can point out a link or has what I need for sale... thanks for any help...I found this on ebay... but the seller didn't have any idea...
http://www.ebay.com/itm/360466901937...S:1123&vxp=mtr
Old Jul 2, 2012 | 01:14 PM
Bo185's Avatar
You need a 4.8/5.3L dished flexplate just find a used one.
Old Jul 2, 2012 | 02:33 PM
Cecil07's Avatar
Thanks alot Bo185.... Thats all I wanted to hear... I found one with bolts already... thanks again...
Old Jul 2, 2012 | 04:37 PM
74novacustom's Avatar
you will also need to reuse the LQ4 crank spacer with the 4.8/5.3 flexplate
Old Jul 2, 2012 | 04:42 PM
Cecil07's Avatar
Really?....
Old Jul 2, 2012 | 04:48 PM
i have the same combo, but i have a slightly older 4l60E trans, i used the 5.3 flexplate with a hughes crank spacer, the 6.0 spacer with the 6.0 bolts should work the same
Old Jul 2, 2012 | 05:06 PM
Cecil07's Avatar
Is your tranny the bolted on bell housing?... I thought the newer trans didn't require spacer... Just the older style ones did
Old Jul 2, 2012 | 05:37 PM
yes mine is, about 18k miles on the combo in the car. I didnt think i needed the spacer until i checked it. My torque converter only went about 1/8 of an inch into the crank. so i had to run the spacer, i guess just check yours to make sure.
Old Jul 2, 2012 | 06:09 PM
Bo185's Avatar
If the 4l60e was used behind a Gen III, then you DON"T NEED THE SPACER!!! The 4l60e used with the Gen I L31 350, 305, and 4.3L will need a crank spacer and elongate the verter holes.
So which 4l60e do you have?
Old Jul 3, 2012 | 11:36 AM
This sounds correct, my 4L60E was from an astro Van behind a 4.3. i did need a spacer and elongated holes.
Old Jul 3, 2012 | 12:47 PM
Cecil07's Avatar
Mine came from a pickup with a 5.3.... I was sure it didn't need a spacer ... I just wasn't sure exactly which flexplate I need ... Found one .. With bolts.. 5.3.... Thanks guys...
Old Jul 3, 2012 | 11:20 PM
flywheel's Avatar
My lq4 came out of an 03 yukon w/4l60e 4x4 so i got an 4l60e out of an 05 2wd pickup w/ 5.3 in it. So why wont the 6.0l flex plate work with another 4l60e?????
Rick.
Old Jul 4, 2012 | 12:17 AM
Bo185's Avatar
Rick.
Yes that year the Yukon denali's got the LQ4 motor and 4l65e that's why it bolted right up. The LQ4 and LQ9 were used with 4l60/65 applications. With the LQ4 being rarer offering infront of the 60's. This wasmost noticeably used in the Hummer H2's LQ4 with a 4l60/65 trans. With the majority of LQ4's the 4l80/85 was used. The LQ9 never came infront of a 4l80 trans. That's why I stated a Gen III 4l60e needed a dished flex plate. Which was evident in your case.
The spacer used on the 4l80e trans with the flat flex plate, will cause the longer hub of the Gen III 4l60e to stick to far out form the flex plate and will break the front pump or just not bolt up.
The 4l80e hub is shorter like the SBC/4.3L 4l60e hub. Then Gen III/IV 4l60/65e hub is much longer. Pictures are in my SIG link of the two with pictures of the different verters.
Old Jul 4, 2012 | 07:53 AM
Cecil07's Avatar
that link should be a sticky somewhere if not already... I searched for hours till I posted this thread....
Old Aug 10, 2013 | 10:08 AM
Lsxstang91lx's Avatar
I recently just swapped my 2004r for a th400. My question is my setup is a lq9 and I was using a ls1 tci flexplate with a hybrid PTC converter that had a ls1 backing plate. The guy I traded has a 03 lq4 and he was using the stock flexplate with crank adapter. We ended up just swapping flexplates and I took his spacer. Will this work on my lq9 or do I need to use a ls1 flexplate with a crank adapter ? Thanks for any advice.
Old Aug 19, 2022 | 12:28 AM
Jamesd2013's Avatar
Default 06 lq4 to 05 4l60e
I was wondering if I'm able to connect a 06 LQ4 from a 2500hd silverado to a rebuilt 05 4L60e 1500 silverado, would I just need to use the flex plate from my 5.3 motor im taking the transmission from.
Or should I just drop the 5.3 and 4L60e into the 2500hd? Totalled the frame of my 05 1500 and kept the power train, have a good lq4 with a bad trans. Just trying to think of the best thing to do.
Old Aug 19, 2022 | 12:39 AM
The 4L60E is a good tranny, but a 6.0 would be a bit more than it was designed for.
It can be beefed up with 4L65E parts, which will extend its life.
If your 4L60E was built with 4L65E parts (many are by the major rebuilders), it should be OK, but don't push it too hard.
