Steve68's Nova SS....
Also, use a heat gun on low to help the dyna mat lay out...helps a lot.
Need a couple longer bolts for the seats, finish the Dynamat, install the seats, start wiring up the fuel pumps,
Got a line on a 6.0 w/4L80E from a 2001 truck, iron block and heads, but complete,
Seats are prefitted, layed down more dynamat, mounted the drivers seat,
dynamat daynamat, then shifter mounts
Found out that my friend opened her Upholstery shop back up, now I can get the rear seat to match the front pattern.
FYI, Procar sells the fabric to cover the rear seat like the fronts.
thanks!
I also pulled the center console from the Neon, so I'll be bolting that in shortly (like so).
Love the car.
