LS1 to '65 Mustang motor mounts? Anyone make them?
Putting a LS1 in my father's Panoz. The chassis is already setup for a '65 Mustang motor mount. I figure someone makes the mount I need already vs. making a custom one. Not having much luck finding one though. Anyone know of any?
Current blow up POS SBF, but it shows the '65 musang style mount
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/582684_3862683056800_1114524769_n.jpg)
Thanks,
Brian
Thanks,
Brian
The 4.6 mounts will probably work fine but it depends on how close your firewall is to the back of the SBF. I found I had to enlarge one of the holes (two holes on the same side) the 4.6 mount to get it to line up adequately with the LS1 block mounts.
I also just used some cheap $30 used solid 4.6 mounts, cut the "third hole" leg completely off, and welded on some 3/16" angle steel so the mount bolted to the four original holes on the LS block instead of using the spacer. All the spacer will do is make the engine sit a small amount higher than it would without the spacer.
Yeah I think this will work... will try it out...
![](http://img14.imageshack.us/img14/4495/mountu.jpg)
http://www.pro-touring.com/showthrea...x-1967-Mustang
i just put one in my 67 mustang. i used some spare 69 camaro 350/z28 motor stands and skinny tall energy sbc motor mounts with 1/2" thick sbc ebay adapter plates.
you are going to play hell getting the exhaust to work with the shock towers. i am going to attempt a 351w header flange swap in hopes of keeping the stock steering.
i was able to make the center link and power steering ram fit under a GTO oil pan. i fabbed up my own center brace since the GTO pan hung too low to keep the original.
I made my own due to aftermarket sub frame but it wasn't difficult. After looking at josh's. Dirty dingo mounts I would have tried them. The thread is ugly betty and its a lq4 into a 66 stang
