Verifying info on LS to TH400 flex plate...
Old Jul 13, 2012 | 04:18 PM
Silver Sleeper's Avatar
Default Verifying info on LS to TH400 flex plate...
i have searched and just want to double verify that the 6.0 flexplate with the spacer will in fact work with my 4.8 to TH400 swap...correct?
http://www.ebay.com/itm/New-OEM-Flyw...ht_2093wt_1185
Old Jul 13, 2012 | 08:19 PM
Anyone?
Old Jul 13, 2012 | 08:47 PM
the_merv's Avatar
Veteran: Air Force
Yup...
Old Jul 13, 2012 | 08:50 PM
S10xGN's Avatar
I don't recall if the 4.8 has the +0.400" "long" crank or the short. That kit will work on the short face crank (which is much more common), the short crank is almost flush with the rear cover. Don't forget, you'll need longer bolts too.
Old Jul 13, 2012 | 09:08 PM
thanks for the info!! i will double check my crank before i place the order
Old Jul 13, 2012 | 09:35 PM
Bo185's Avatar
Just note the spacer faces the crank when using the flat flex plate.
Old Jul 14, 2012 | 12:50 AM
the_merv's Avatar
Veteran: Air Force
Early 4.8 has the longer crank.
Old Jul 14, 2012 | 04:22 PM
i have a 99 4.8
Old Jul 14, 2012 | 04:52 PM
Bo185's Avatar
Look and see if you have the thick flange. It will stick out about almost 1/2'' from rear cover. If so then you will not need the spacer or longer bolts. Just place the flat flex plate on and elongate the TC holes in the flex plate.
The 4.8L standard transmission crank (1225312) is wide/thick. The 4.8L automatic transmission crank (12553482) is a narrow. The wide/narrow crank scenario happened in ’99-’00; after that they all became narrow flange.
Old Jul 14, 2012 | 05:03 PM
the_merv's Avatar
Veteran: Air Force
4.8 with a 4L80E has long flange.
Old Jul 14, 2012 | 05:52 PM
tta656's Avatar
you guys are confusing the **** out of me....
i have a 2005 5.3 silverado motor and using a 4l60e...do i need a spacer
sorry to highjack
Old Jul 14, 2012 | 08:24 PM
S10xGN's Avatar
sorry to highjack
Short crank = flush with rear cover, needs spacer.
Long crank = 0.400" out of rear cover, no spacer.
Old Jul 14, 2012 | 08:45 PM
im confused as well so i took pictures of my 4.8 with the stock flexplate still installed....from the pictures i took, it looks as if the the crank sits flush with the rear main seal...does this mean i need a spacer?
Old Jul 14, 2012 | 09:31 PM
Bo185's Avatar
Negative, the 4.8L 99-00 had the long flange with the NV3500 manual. The 4.8L was never used with the 4l80e till 2002 or so full size vans at that point it used the short flange and a spacer.
Old Jul 14, 2012 | 09:33 PM
Bo185's Avatar
That looks like a dished flex plate. You need the spacer after that flex plate to support the verter hub of the Gen I/II trans.
Old Jul 14, 2012 | 09:43 PM
so do i buy the flat flexplate and spacer or do i use my dished flex plate and spacer?
ive searched and could never get a definitive answer on the 4.8
Old Jul 15, 2012 | 12:16 AM
Bo185's Avatar
I gave you the definitive answer. You have the dished flex plate. Your 4.8L was used infront of a 4l60e.
All you need to do is buy the spacer or even just the Hughes bushing it is cheaper and rides on the crank flange no need to even un-bolt the dished flex plate, but you still have to elongate and the holes in the flex plate were the verter bolts up. Read the link in my SIG!!!
Old Jul 15, 2012 | 06:11 AM
thank you very much!! you just saved me a few bucks...im just going to buy the hughes spacer and run it..
as far as the flexplate mounting holes go...how much should i open the holes up?
Old Jul 15, 2012 | 06:00 PM
Bo185's Avatar
I would remove the flex plate and use the hughes spacer as a guide to align the flex plate to the converter. Mark and elongate the holes, then reinstall flex plate, use lock tight and torque bolts. Then using RTV or even superglue to temp hold the spacer into the end of the crank till you bolt up the trans and converter.
Old Jul 15, 2012 | 06:09 PM
the_merv's Avatar
Veteran: Air Force
Ah ok..seen a long 4.8 one time, was told it had an auto behind it..
