g body power steering lines
Old Jul 15, 2012 | 09:19 AM
86SS86LS's Avatar
Default g body power steering lines
What are all of the g body swaps using for power steering lines? More specifically, I'm using a 5.3 power steering pump in an 86 monte.
Old Jul 15, 2012 | 01:36 PM
jlcustomz's Avatar
When I did mt swap 9 years ago, I had a local hydraulic shop make what I needed for ps & fuel connections.
Old Jul 15, 2012 | 05:13 PM
mikes87ss's Avatar
Default power steering lines
Ihave l92 w/corvette fdea on it.For the pressure line I used part #177 made by Omega brand.It has a port on it for the pressure sensor that was on my monte from factory.the return line is part #963 which is just an elbow/nipple with transmission hoe attached.This is in my 87 monte carlo ss.Ido a ton of business with our local Federated Auto Parts and they let me go through the Omega power steering book and I ordered 10 hoses in that had correct ends as a stock monte ss hose had.I found one that fit and sent the rest back.
Old Jul 15, 2012 | 06:01 PM
tta656's Avatar
http://www.showmetheparts.com/omegahose/
the 177 doesnt have an extra port and the 963 is not found...please help..
Old Jul 15, 2012 | 06:11 PM
the_merv's Avatar
Veteran: Air Force
LS1 Fbody
Old Jul 16, 2012 | 10:57 AM
kmw0481's Avatar
I used the original lines that where on my car. On the pressure line I just screwed the fitting out the back of my factory MC PS pump, and insalled it into the LS truck pump. No problems works fine
Old Jul 16, 2012 | 12:32 PM
spacemanspif's Avatar
X2. Take the old fitting (and spring and valve) out of the back of your Monte pump and put it in your truck pump. If you threw away your pressure switch that runs inline with your pressure hose, get a pressure line for a non-A/C car.
Old Jul 16, 2012 | 07:34 PM
t72ss402's Avatar
I ended up using an S10 gearbox. The lines(f-body) thread right in.
Old Jul 16, 2012 | 09:39 PM
86SS86LS's Avatar
Thanks for replies......Looks like the most straightforward option will be to use factory g-body hoses. Problem is I no longer have them.....so I'm off to the pick and pull. Do most mid 80's gm vehicles (caprice, trucks, vans, etc.) use the same style hose?
Old Jul 17, 2012 | 02:25 AM
jmd's Avatar
jmd
F-body hoses of similar years work and are just routed slightly differently. Minor tweaking can be done by hand. 1980 and up has compatible fittings.
The sensor port is irrelevant for an EFI swap; all it accomodates is a switch that cuts out AC compressor power.
Old Jul 18, 2012 | 03:12 AM
85GPLEf41's Avatar
Originally Posted by the_merv
LS1 Fbody
i used my stock 99 ls1 f body lines and they bolted in fine but i wasn't fully satisfied with the way the pressure line went in... Any pics of your set up?
Old Jul 18, 2012 | 12:36 PM
the_merv's Avatar
Veteran: Air Force
This is the best pic I have..the return side was extended and looped so it would cool down a little bit..
