cutting primary tubes off header flange
I may need to do a 351w ls1 flange swap inorder to keep my 67 mustang project rolling.
This piece of pipe, in a vise, with a hammer, is what you need to "round off" the ports:
also i take it your rounding pipe was 1-3/4 and flattened to fit inside the square flange. do you think a cheap pipe expander from harbor freight would be enough to round the tubes out? wouldn't necessarily be stretching the pipe beyond its natural diameter.
Rounding the tube is not rocket science, just brute force. Whatever works best for you. I used a piece of 1" pipe flattened to 1 3/4" wide so the wide edge just fit into the diagonal of the square tube, then just work it around until it's close to round. Liberal use of a 2# ball-peen hammer helps.
i settled on some patriot 1-3/4 flanges. they came with gaskets and bolts and were less than $50.
i also ordered a pipe shaper tool for rounding the tubes.
midway down this page goes over making a set...I use an old GM sway bar with end ground into a wedge shape, works great for shaping the tubes. I also use a acetylene torch, propane hand held doesn't get hot enough.
did you mig or tig? i only have a mig using .025 wire. just wondering if it is enough to close the gaps out from the outside. do you have any pictures of your finished welds?
btw. i have all my parts.
oops the flange is upside down...
