lq4 in 68 firebird 400
here it is,
lq4 in 68 firebird 400,all black car,power nothing,install picking up speed,2005 lq4,.581 cam,victor,850 carb,gt45 turbo,th400,2800 stall,342 gears,trying to make a tight package of it for future swaps,
charles
any info on prelubing before start up would be great
charles
anyone on this,thoughts on prelube b/4 start up,,echo..............
anybody have knowledge on the subject,,anyone out there??? did i post wrong section,,,echo...
If you've used assy lube, pull the fuses for spark & fuel pump. Then, crank till pressure is achieved.
To get start-up pressure (50-60lbs), I had to crank 3 or 4 times for approx 10 seconds each. Afterward, replace fuses, then try starting.
The first time I attempted pressure, everything oiled up just fine, without priming the pump.
More recently, after a rebuild, the pump had to be primed with vaseline, bec the pump was sucking air, & I couldn't achieve pressure, otherwise.
Best of luck with your project!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
