chevelle NW 92mm throttle body air intake
I have a Nick Williams 92mm drive by cable throttle body. Anyone running this? if so what cold air intake and filter setup are you using?
I just installed a fast 92 and reused the same intake stuff (all of it) that I had been using with my stock ls1 tb. Turns out the outer diameters are pretty much the same, so everything fit. Every "cold air intake" is pretty much going to be a tube, probably made in china, and will have few if any features making one different than another, though some might have an extra port here or there. I got a spetre one from advance, but only because the code "visa" made is cheap and I needed one asap.
