IS300 LSx Build / Initial Startup
EDIT: Heres an article LSXtv.com did on the car on 10/2/12....
Swap Insanity: Turbo LQ4 Powered Lexus IS300 - LSXTV
Specs:
01 Lexus IS300
07 6.0L LQ4
Built 4L60 Trans
Precision Industries Billet Triple Disk 3500 Stall Converter
Kurt Urban Rings
Clevite Rod Bearings
Brute Speed Blower Cam 232/240 .595 .608 115LSA
PRC 199-650 Springs, Titanium Retainers
90MM TB
FAST Rails
Bosch 044 Fuel Pump
80LB Injectors
Aeromotive Regulator
Ported Oil Pump
Billet Timing Set
76mm On3 Turbo (to be installed next week)
On E85 shooting for 6-650whp
Heres some pics:
Heres a vid:
Thank you sir
the best feeling and the most nerve wrecking lol
Clean install. Isn't the turbo gonna on the thermostat/housing? What black braided hose and fitting did you use for your fuelrails? What is the procedure to install s fitting on them? I never did SS hose stuf before, so please pardone my questions/ignorance.
thanks,
Jim
Some of Jons welds tonight. He was a little under the weather today but still managed to do a great job as always.
Mockup of the passenger side
Passenger side done
We left the passenger to driver side unwelded as this is where the flex will go tomorrow.
Heres how we left it for the night. It will go up in the air tomorrow to get the downpipe finished. I plan to run an aluminum exhaust after it exits over the front K-member
thanks,
Jim
The thermostat housing will be modified with a new neck to run to the lower radiator hose. I used Jegs Pro-Flo hose. Heres the link: http://www.jegs.com/p/JEGS-Performan...61335/10002/-1
For the fittings I used Jegs AN fittings, heres the link: http://www.jegs.com/p/JEGS-Performan...57777/10002/-1
Its pretty simple really to install the AN fittings. Heres yet another link on how to do it, its easier than me trying to explain it to you lol. It is A LOT EASIER to assemble the fittings and line using the Pro-Flo line as opposed to the stainless braided line in my opinion....and the black looks better too I think:
