LSx prep; electric fans
If possible, You might be able to have your Jimmy's current PCM/BCM tuned to handle the Fans.. ??
BC
http://www.haywireinc.com/index.cfm/...prod/prd51.htm
On dads chevelle the 1 16" at slow speed will keep the car 191 all day in 100 temps.
My car will stay 180's with 1 fan very rare for it to go to high speed and use both fans unless it it very hot outside
you get what you pay for in fans and controlers.
Tim
I like Dakota digitals fan controller. That's what I'll be using when I setup my dual fans.
The dual on my car has been there since 05 been on drag week.
Did you contact Spal to see if they would stand behind it?
Tim
At any rate, I think aftermarket fans are rediculously loud. My 16" sounds like a jet coming down the road when it kicks on.
SPAL is no longer marketing the PVM Controller anymore.. so if this one fails. I am out of luck and will have to go with something different.
The SPAL Fans and the Controller have worked well over the years..
BC
I hate to say this but don't buy a SPAL fan. No offense to the guys that have them but I can't begin to count the number of hate posts I have read on those. For $20 you can grab an OEM fan and the relays needed to drive them from a J/Y. Chances are a Taurus fan on slow speed is all the air flow you will need. You can pay more for a SPAL fan, much much more, but I just don't see the benefit AND you run the risk of it not working as well as an OEM pullout. Just too many horror stories out there.
Like I said, if you grab a fan from a JY make sure and get the relays that feed it.
Also...love the $40 Windstar dual fans. Cheap, very available, and move a lot of air.
