G-body LS swap and a/c: my solution
Old 08-22-2012, 10:59 PM
pmgm's Avatar
Originally Posted by lt4malibu
no its not, ill check later i think it was 97 inches but im not sure.
Hello, Just wanted to know if you found the part # for the belt you used?
Thanks
Old 08-23-2012, 07:43 PM
lt4malibu's Avatar
Sorry forgot about that:
Belt i ended up using is a 6PK2454 gates number K060966
Old 08-24-2012, 11:52 PM
01cherryreds10's Avatar
What tensioner does it use? Any chance ill be able to keep my billet katech tensioner?
Old 08-25-2012, 10:03 AM
lt4malibu's Avatar
it uses the corvette Gm tensioner #12559325 and Gm smooth idler #12564401, it says specifically in the directons aftermarket ones like the katech wont work but i dont have one so i cant say for sure.
Old 09-30-2012, 01:34 AM
roach4047's Avatar
Subscribing
Roach
Old 10-08-2012, 10:41 AM
TxFireman1972's Avatar
VERY good info. About to do a LS swap on a 89 Mustang and definitely want to keep the AC. This info should definitely help. Thanks for the write up!! Did you happen to make a diagram of your actual harness? Or take any pictures? Thanks again!
Old 10-08-2012, 10:52 AM
lt4malibu's Avatar
the schematic is posted on the first page, its just a little jumper harness with @ 6 wires and a relay.
Old 10-08-2012, 10:53 AM
My bad, it didn't show up the first time I looked. Thanks!!
Old 12-03-2012, 06:49 PM
fox12303's Avatar
Default Sanden SD7 mount.
The Holley mount looks really nice and can't beat the price. Anyone have pictures of the SD7 installed? What pulley offset does it use? Corvette?
Attached is a picture and link to one i've made. The down side is it uses the truck offset and modified F-body waterpump. The compressor tensioner setup has been installed in my 72 Malibu for a year now and has been great.
https://ls1tech.com/forums/conversio...ory-drive.html
Attached Thumbnails G-body LS swap and a/c: my solution-359933d1340285779-f-body-truck-hybrid-accessory-drive-available-dscf3680.jpg
Old 02-13-2013, 06:58 PM
ijimmy's Avatar
seting one up now with a sanden compressor , i think that is a diferant bracket pictured with the pancake compressor , i had one of those compressors once bought with a gm accesory drive for a sbc , they suck some horsepower and put alot more drag on the engine than a sanden unit , had to use a stepup throttle selinoid with it , or it would kill my smallblock with a big cam , will post pics when done went with the complete holley system as old ( a bodies) have issues with steering box clearance going on an 08 ly6 and into a 64 chevelle with power stearing
Old 10-06-2013, 01:58 PM
dynodanmanda79's Avatar
Where did you mount the 3-wire pressure sensor that the pcm has to see in order to kick the compressor on? Is there a port on the high side line?
Old 10-06-2013, 02:01 PM
  #32
lt4malibu's Avatar
welded it in the high side line, basically cut the factory g-body line in 1/2 and sectioned in a piece of the f-body line that had the pressure switch
Old 12-26-2013, 08:16 PM
  #33
Mighty Whitey's Avatar
I love it!
I'm wanting to retai the factory a/c compressor ( still charged just laying to the side lol) on my '94 z71, and that Holley bracket makes it look MUCH easier to obtain.
Now... Just gotta see If they sell one with the truck bracket offset or if I'll just have to make spacers...
Old 12-26-2013, 08:48 PM
  #34
lt4malibu's Avatar
They have different spacers for the corvette, f-body and truck accessories - check the Holley site
Old 02-25-2014, 06:02 PM
  #35
Phillipm's Avatar
Did you ever have trouble not having the diode? Did anyone try installing it the other way around like mentioned?
Old 02-25-2014, 06:35 PM
  #36
lt4malibu's Avatar
i put it in the other way and it worked great, guy who bought the car off me never had a problem with it either. i would definately use the diode otherwise it could backfeed.
Old 02-27-2014, 01:04 PM
  #37
Phillipm's Avatar
Okay thanks for the update. Cannot believe GM screwed up the schematic... Oh wait. Yes I can. Although very obvious if you know what you're looking at I suppose.
Old 02-28-2014, 10:38 AM
  #38
lt4malibu's Avatar
I work on these things all day every day and I didn't even notice it (till it popped the fuse lol)
Old 06-30-2014, 07:46 PM
  #39
BAerMonteSS83's Avatar
I'm having trouble getting the factory 87' Cutlass AC line installed on this set-up. I have the BRP mounts and wonder why I can't get it to line up to install? Errr. It's so bad that I am wondering if I have to chop this new 87' line apart in order to have customized lines made to work. I'm wondering if you had to ben yours to get it to line up to fit???
Any help would be greatly appreciated!
Thanks!
Old 06-30-2014, 10:01 PM
  #40
lt4malibu's Avatar
yes I did bend them slightly, but which line are you talking about?
Quick Reply: G-body LS swap and a/c: my solution
