G-body LS swap and a/c: my solution
Old 08-03-2014, 11:13 PM
  #41
1967camaro78's Avatar
I was looking at buying this bracket to put on 6.0 that I am building now for my 89 c1500 and just saw you have to buy a spacer kit also that makes the bracket not so cheap anymore. Do you actually need spacer kit or can you make your own?
Old 08-03-2014, 11:28 PM
  #42
lt4malibu's Avatar
You need the spacers
Old 08-04-2014, 10:13 AM
  #43
autocomman's Avatar
FYI bracket I ordered was from LS brackets, guy supplied spacers and al the hardware, he sells 3 diff kits depending on what motor, crank pully you have. I havent run it yet,but it all lines up fine first time with the truck motor
Old 08-05-2014, 12:51 AM
  #44
autocomman do you have any pictures of your setup?
Old 12-16-2014, 11:56 PM
  #45
Patro46's Avatar
Originally Posted by ealvarez11
I did almost same thing to my 1977 C3 Corvette except I used Kwik Performance a/c bracket so that I could us new style Sanden Compressor. I did use 02 Camaro condenser with stock corvette accumulator and heater. I used custom lines (half camaro / half c3 corvette). I am using high pressure switch (port welded as well) and also sending a/c request signal to PCM in order to increase idle before a/c clicks on. I kept stock corvette HVAC controls.
Yup.... What he said...
Quick Reply: G-body LS swap and a/c: my solution
