Project Volv8
Old Aug 7, 2012 | 08:35 PM
safarimike's Avatar
Default Project Volv8
1994 Volvo 940 Wagon
05 LQ9/4l65
Tim at Liquid Iron Industries banged out the motor mounts and trans mount Sunday. Got it back to my house Sunday night. The stock truck pan is going to need a lot of cutting to work. Marked the pan and dropped it off to tim to get it cut. Hope to have it ready for a test fit in a day or 2.
Trans mount. It still uses the factory rubber mount underneath of it.
Empty engine bay. Pulled the motor out tonight to measure for pan clearance.
Motor mounts. Still uses the factory mount. I have been looking for 940 poly mounts but no luck. Thinking of making hockey puck mounts.
Look at those welds!
1/4 inch spacers used to drop the sub frame or more clearence
lots of work left to do. updates to come.
Old Aug 8, 2012 | 07:27 PM
Jimbo1367's Avatar
Gonna be a killer ride!
Old Aug 8, 2012 | 08:56 PM
aknovaman's Avatar
Searching Craigslist for one with a exploded engine. Confused on which model and year wagons are rear wheel drive.
Old Aug 8, 2012 | 09:42 PM
safarimike's Avatar
240 740 and 940 all rwd solid axle. 960 is rwd but independent.
Old Aug 8, 2012 | 09:48 PM
safarimike's Avatar
no turning back now! hope to have the pan welded up tomorow.
messing with the idea of hockey puck motor mounts. got 2 pucks in there now which is a bit shorter than the stock rubbers with the weight on them. i think 2.5 pucks will be the ticket. sitting on the top puck is a 3/16 piece of plate i had tim cut out for me on the torchmate.
Old Aug 8, 2012 | 10:23 PM
aknovaman's Avatar
How low is the truck pan? Think the cts-v or LH8 or F-body pan would work better?
Old Aug 9, 2012 | 06:00 PM
i r teh noobz's Avatar
Why not go solid? I hear hockey pucks don't last but a year or two.
Get a bag of giant washers and stack until you hit your desired height. Then weld them together.
They list as out of stock, but perhaps Z31 poly mounts will work. They use a similar setup and appear to be close to the right height.
Merkur XR4Ti also used a similar mount to your stockers. MC2 Racing may have something for them.
Old Aug 9, 2012 | 08:54 PM
safarimike's Avatar
tried the c5 batwing pan and the f body pan - neither of those fit any better than the truck pan.
Old Aug 9, 2012 | 08:56 PM
safarimike's Avatar
tim got the pan ready to go, just needs a coat of paint.
Old Aug 10, 2012 | 08:04 AM
Looks like the Turbotime pan. Good work. Welds look really nice, especially considering that the pan is cast.
Old Aug 12, 2012 | 03:11 AM
Benwb's Avatar
Anyway you could send me the dimensions/layout of the mounts? or would your fabricator be able to make copies? pm me if needed
Old Aug 12, 2012 | 08:53 AM
aknovaman's Avatar
Why did you not use these mounts:
http://www.liquidironindustries.com/...cat=598&page=1
$52
Old Aug 12, 2012 | 08:42 PM
safarimike's Avatar
$52
you still need to fab something that comes off the cross member for those mounts.
benwb, if you contact tim@liquidironindustries.com im sure he can help you out.
got the motor and pan bolted up today. tried to drop the motor and trans in as one unit but you cant do it that way, the pan wont clear the cross member. and if you try to unbolt the pan and leave the trans bolted up, then you cant install the pan because the trans and the cross member get in the way.
got the shortys bolted up but they are going to need some modication at the collector end.
driver side
pass side
how are you supposed to get a plug wire on that without it burning through?
the hood almost closes. it hits at the throttle plate motor. ill have to add some washers to the hinges.
i only have 4.5 inches of ground clearance at the oil pan, going to need to get a skid plate for that.
Old Aug 12, 2012 | 08:44 PM
73AMC's Avatar
Wow, what will your oil capacity be? Looks great by the way. I welded all my own stuff and it doesnt look nearly that nice.
Old Aug 12, 2012 | 10:15 PM
safarimike's Avatar
not sure, im hoping at least 5 qts. im going to run a big oil cooler to try to gain some capacity back.
i haven't welded anything on this project. im not a very good welder and i dont want this thing to look like a hackjob swap. tim at liquid iron industries is doing all the welding for me.
Old Aug 13, 2012 | 02:54 AM
lordvs666's Avatar
What are your plans for the motor?
Old Aug 23, 2012 | 07:38 PM
safarimike's Avatar
mod wise? stock for now. eventually i want to cam/pushrods/springs and get a converter for it. there is a custom grind pred z cam that guant was running a while ago (dont know if he still is) that had an awesome torque curve, perfect for the street. going to need to address the rear end before any engine mods.
not many updates latley. chopped and flipped the tac pedal, in its stock form it was way to long and was hitting into the trans tunnel. got it tacked together right now, gotta weld it tomorrow. gonna use the stock bolt hole in the fire wall for the top mounting hole, nut and bolt the bottom one through the firewall, gonna have to pull some of the carpet up.
Old Aug 23, 2012 | 11:54 PM
97camaroguy's Avatar
Hey Mike,
Great build so far! Really killer stuff. If I could chime in on the spark plug wire dilemma. Have you considered header wrap? Also there are protective sleeves you can buy that go over the plug wires.
Hope this helps you out a bit.
Chris
edit: looked at the pic again and you may need to dimple the header a bit.
Old Sep 9, 2012 | 06:30 PM
safarimike's Avatar
engine, oil pan, and trans are sitting in together for the first time! didn't get any pics of the new pan, but we didn't cut it up as much. mainly just the underside of it. i can acutally get all 4 bolts in on the baffle, on the old pan the front bolt holes were not even there. the pick up fit, but i had to chop the cross member a little to fit the pan. i am planning to add some bracing to the cross member to make up for the parts i cut out.
cross memeber pic after cutting. a little hard to see where i cut it.
i also had a harbor freight cut off wheel explode in my face today. luckily i had my glasses on. my friend who was standing about ten feet way got hit on his lip with a piece of the wheel. never going to use those wheels again.
ive been slacking on my picture taking lately. ordering coolers and exhaust pieces tonight. hopefully going to attack the wiring this week.
Old Sep 9, 2012 | 06:38 PM
Jimbo1367's Avatar
How about some shorty header plugs?
