LQ4/T56 into 05 Subaru Legacy
Well, we made some progress today. The day started off on a bad note as we found somebody had stolen the cats from the van and two other cars that were parked in front of the shop.
After we filed the police report, the got better and we were able to pull the motor out of the van. I started tearing it down and everything looks good so far. I will update with pics later
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Nice build
We are doing 2 builds simotaneously. The LM4 Miata Frankenstein and this one
I bought some L92 heads as well as an L76 intake to match
My questions are, what is a cam that makes good power but is known not to cause PTV issues with the LQ4/L92 combo
Can I mill the L92's to raise compression without issues?
What throttle body to use with this to be compatible with my 03 ECU?
#36
Here is where the parts collection stands now:
LQ4 6.0L Block
L92 Rectangle Port Heads (will be milled down to get compression around 10.5:1)
Billet Timing Chain Kit
GTO Front Sump Oil Pan and Pickup
Comp XR273HR Camshaft (220/224 .530/.534 112LSA)
LS3 Blue Springs
L76 Intake Manifold
LS7 Fuel Rail
LS3 Corvette Water Pump
LQ4 6.0L Block
LS3 Blue Springs
L76 Intake Manifold
LS7 Fuel Rail
#37
being a Subaru owner myself.... this is awesome lol have you posted this over on NASIOC? people would get pissed if they knew about this I'm sure haha definitely following this!
#39
The motor is coming together very nicely now. Just need to pick up injectors and a few other odds and ends
LQ4 6.0L Block
LS3 Blue Springs and Retainers
Melling OEM Oil Pump
L76 Intake Manifold
LS7 Fuel Rail
LS3 Corvette Harmonic Balancer
LQ4 6.0L Block
L76 Intake Manifold
LS7 Fuel Rail
#40
LQ4 6.0L Block
L76 Intake Manifold
LS7 Fuel Rail
LQ4 6.0L Block
L76 Intake Manifold
LS7 Fuel Rail
