Fuse Block Pinout
a7 pnk
a10 blk/wht
a12 pnk
f1 blk
f2 pink
f3 ppl
f9 blu
f10 lt blu
f11 pnk
f12 grn
The colors might be slightly off, ie grn might be dk grn. but I know that f3,ppl is the crank power.
Thanks for the help.
Here are the pics of the connector:
http://www.j-a-m.net/Pics/Tahoe/ls6%20swap/C2_1-sm.jpg
http://www.j-a-m.net/Pics/Tahoe/ls6%20swap/C2_2-sm.jpg
http://www.j-a-m.net/Pics/Tahoe/ls6%20swap/C2_3-sm.jpg
I always seem to get stuck with the odd ball stuff :/
I wonder if I can get a hold of the seller and get the VIN.
I guess I'll have to do it the hard way...
here's the pinout:
Pin
Wire Color
Circuit No.
Function
A1
PNK
839
Ignition 1 Voltage
A2
Not Used
A3
BLK/WHT
451
Ground
A4–A5
Not Used
A6
PNK
639
Ignition 1 Voltage
A7–A12
Not Used
B1
PNK
839
Ignition 1 Voltage
B2
PNK
339
ignition 1 Voltage
B3
Not Used
B4
BRN/WHT
419
MIL Control
B5
PNK
639
Ignition 1 Voltage
B6
ORN
340
Battery Positive Voltage
B7
ORN
340
B8
BRN
241
Ignition 3 Voltage
B9–B12
Not Used
C1
PNK
839
Ignition 1 Voltage
C2–C3
Not Used
C4
GRY/BLK
87
Cruise Control Resume/Accel Switch Signal
C5
PNK
639
Ignition 1 Voltage
C8
DK GRN
59
A/C Compressor Clutch Supply Voltage
C9
DK GRN
WHT
459
A/C Clutch Relay Control
C10
WHT
375
Skip Shift Indicator Control
C11–C12
Not Used
D1
PNK
539
Ignition 1 Voltage
D2–D3
Not Used
D4
WHT
121
Engine Speed Signal
D5
PNK
639
Ignition 1 Voltage
D8
PPL
420
TCC Brake Switch Signal
D9
Not Used
D10
PPL
421
AIR Solenoid Control
D11–E1
Not Used
E2
PNK
839
Ignition 1 Voltage
E3
PNK
339
Ignition 1 Voltage
E4
GRY
397
Cruise Control On Switch Signal
E5
PNK
639
Ignition 1 Voltage
E6
BRN
241
Ignition 3 Voltage
E7
BRN
241
Ignition 3 Voltage
E8–E9
Not Used
E10
DK BLU
473
High Speed Cooling Fan Relay Control
E11
Not Used
E12
DK GRN
WHT
465
Fuel Pump Relay Control
F1
DK GRN
335
Low Speed Cooling Fan Relay Control
F2
PNK
839
Ignition 1 Voltage
F3
LT BLU
20
Stop Lamp Supply Voltage
F4
DK BLU
84
Cruise Control Set/Coast Switch Signal
F5–F6
Not Used
F7
BRN
241
Ignition 3 Voltage
F8
Not Used
F9
BRN
436
AIR Pump Relay Control
F10
PPL
6
Starter Solenoid Crank Voltage
F11
PNK
239
Driver 36 Volt Reference
F12
BLK
150
Ground
