What to do about fuse box?
Old Aug 9, 2012 | 04:03 PM
superdave84's Avatar
Default What to do about fuse box?
I could have sworn that the engine I bought had a fuse box included but it turns out it doesn't. Should I buy a used fuse box matching the vehicle the 5.3 came out of (2002 Yukon), or is there another option that is better?
Thanks
Old Aug 9, 2012 | 06:32 PM
85MikeTPI's Avatar
FWIW, I grabbed a small underhood one from an early 2000's Impala from a bone yard.. It's about 4x5
http://www.autofuseboxdiagram.com/36...e-box-diagram/
Grab the mounting brackets and leave 6" of wire into the box to solder your harness to...
Old Aug 9, 2012 | 06:47 PM
SickDenali's Avatar
Don't know if it would help you or not buy I have a complete accessory harness with fuse boxes from a 2000 camaro ls1 for sale.
Old Aug 9, 2012 | 07:25 PM
BOXCHEV's Avatar
Curious what everyone is using as well. I've been trying to work my own harness and following a few things from lt1swap. Really don't care for the little fuse panel he used.
Old Aug 9, 2012 | 07:29 PM
nos487's Avatar
I would like to see some ideas also. I am trying to put everything under dash of my truck.
Old Aug 9, 2012 | 07:55 PM
99VetteFRC's Avatar
I used a small 6 circuit I bought from Auto zone. Has a bolt terminal that I power up from the main relay. It only runs the engine. 1. Injectors 2. Coils 3. MAF 4. TAC 5. Tach Step up curcuit 6. Can't remember. But it was that easy and mounted under dash.
Old Aug 9, 2012 | 08:38 PM
Rocketrod's Avatar
Lots of good suggestions already listed. I built my own using Cooper-Bussman RTMR panel. They are extremley compact and high quality, https://ls1tech.com/forums/16192969-post105.html
