engine starts, runs for 3-5 seconds and dies, sometimes fires & dies immediately
#41
Tac could be the problem, but there have been several, and by several I mean tons of people who after disconnecting their throttle body for maintenance on intake gaskets have had to replace their throttle body. I would look there before I replaced the tac. but thats just me.
#42
1. The S10 does not have a resistor built into the key....too old for that, I think. As far as the column lock setting in the PCM, our guy set it to “NO”. Hopefully that disables the feature.
2. I already ordered the TAC from GM, so will have to see when it gets here. I have more open to my wiring or a damaged harness causing problems than the components, as the components functioned together as a unit before they were removed from the car.
However, I am trying to remain open minded and will keep the throttle body in mind.
Maybe I will “adjust” the harness in some place that it hasn’t been moved (since installation” and see if that changes the symptoms.
#43
If you decide to do something with the harness, wether it be repair or replace pm me. Ill make sure you are taken care of.
#44
Today we took the pCm back to the programmer and he set the steering column lock as follows..The EFI Live asks "Is steering column lock installed?" Before it had been set to "NO". This time he set it to "YES".Reinstalled the PCM & it fired right up & didn't shut off until we shut it off. We're on pretty good terms with the local GM folks and they let us cancel the ordered TAC module.
Now we can get on to working out the other bugs.
I would like to sincerely thank everyone who contributed their time & input to help us resolve this issue. It IS appreciated.
Also, I would like to say that this forum seems to have much more savy people than others that we have tried. Some of them have more "testosterone based" blurbs than technically competent input, guys that just want to brag & be heard.
I hope that I may be able to contribute as well sometime.
When we are on the road, I will try to post some photos of the completed project.
Thanks again!
The following users liked this post:
Joel Clark (09-30-2020)
#48
Just so you know, I have only seen this issue with the 97 and 98 vette harnesses.
OldS10 has confirmed EFI-Live can edit it out.
I can confirm HP tuner can edit it out.
I can confirm LS1-edit is not able to edit it out.
#52
Isn't that the truth! (As part of our business, we build display boards so that at least some of the spectators get a clue as to what some of these guys (& girls) go through to get to the end result. It IS difficult to imagine unless you've been there.) I'm content to be on this side of the "fence".
