2007 and later vortec engines
Thanks for any information.
Bob
If you don't plan on upgrading the camshaft, I'd suggest you keep it (with a slushbox, I don't think the manuals can use it very well).
You can tune it out and run the motor as is and it will not hurt anything.
Or to delete it you need to remove the heads. Remove the 8 AFM lifters and four lifter trays. Install 8 reg. lifters and four lifter trays. Then remove the AFM valley cover and install the correct non AFM valley cover with the orings under the cover to block the AFM ports. Also you need new head gaskets and head bolts. And tune it out of the ECM still as well.
