3rd or early 4th gen 5.3 turbo build?
I'm looking to start a 5.3 turbo/t56 project over the upcoming winter. I am wondering what would be easier/cheaper for actually getting the motor/trans mounted in the car, 3rd gen or lt1 4th gen. Obviously a LS1 4th gen would be easiest but unless I find a cheap blown up one thats out of the question. I have read a few threads that said the truck accecories fit under the hood of a 3rd gen with slight modification. Also the 3rd gen k-member can be made to work pretty easily. I havent found many detailed threads about what parts are needed to mount in the 4th gen tho. Any knowledge would be a big help!
P.S. again this is for fitting of the motor/trans only! I do undertand that there is a lot more to the swap.
Thanks
Thanks
I think overall you would have better luck finding a cheap 4th gen that isn't rusted out, and beat to hell, compared to a 3rd gens, which are creeping up in price.
Also, it's easier to fit bigger tires under a 4th gen, compared to using spacers/etc on a 3rd gen.
well a 93-97 would be a fairly easy swap i believe trans mount and ls front frame with mounts should be easy and cheap enough to find i have a lsT56 trans mount 20$ IMO theyre both cars a PITA to work on. third gen engine drops from the top and LT/LS you drop the whole frt suspension down or pull the body up
Thanks for the input, maybe a 93-97 would be a better idea. Since I'm going to have to get a LS k member and trans mount ect anyways is there anything else that would be different if I bought a v6 car since they are a fair bit cheaper?
1. Brakes: The V-6 models have always had smaller/cheaper brakes, If you care about this figure this cost into your build.
2. Rear diff carrier: A V-6 will not have the locking diff, open gears is what they come with. It is at least the same type (10-bolt) rear end as the V-8 model, and can be upgraded the same way.
3. 2 peice drive shaft: The drive shaft is a 2 peice design with a carrier bearing mounted to the torque arm. This was done by the factory to improve the feel of the car, but would be a weak link for the turbo V-8 you intend to use.
The engine accessories and the low profile intake are the other 2 restrictions. The engine bay is wide and long, but not tall. No tunnel rams without cutting up your car (and windsheild wiper system).
I felt these shortcomings were acceptible, because these V-6 cars still had 3 good points.
1: Parts availibility
2: Lightest generation F-Body
3: Cheap purchase price (paid $1,700.00 for mine)
Pipe in if anyone has more to say, I dought I covered it all.
