04 gto ls1 into 98 camaro z28 NEED HELP!
I recently purchased a 2004 ls1 from a gto that I will be swapping into a 98 camaro z28. What conversion would I need to do to make it work, harness wise?
LSxGuy widda 9sec Mustang
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Harness from 5.7L F-body will work on 04 GTO 5.7L no issues. About the only thing that won't work easily is the later model throttle body. Longblock for Longblock is a direct swap. Oil pan and accessories are different.
Also use the '98 Coolant temp sensor and oil pressure sender.
