ls1 way too rich
Old Aug 21, 2012 | 06:57 PM
BLK02WS6's Avatar
I would consider a mail order tune to be a base tune to get it up and running and get it to a tuner... would be best if the tuner you are taking it to for full tuning could do the base tune...
Old Aug 21, 2012 | 07:00 PM
Gregamuffin's Avatar
So everyone is pretty much agreed on needing a tune? Because it still runs kind of shitty with the maf unplugged and wants to die when giving it gas
Old Aug 22, 2012 | 08:19 AM
Tirefire's Avatar
Dude you need a wideband sensor so you know how rich your setup is. I just got a mail order tune (to break in engine) and my AFR at idle is 14-14.7 and it smells pig rich. I also have headers catted y-pipe and mufflers. I doubt yours smells as rich as mine!! Once I get everything figured out I'll be taking it to the tuner. Make sure you dont have any vacuum leaks that will also make you go rich....
Old Aug 22, 2012 | 02:59 PM
the_merv's Avatar
Veteran: Air Force
I would plug the MAF in..
Old Aug 24, 2012 | 06:00 PM
by no means am i trying to run it without the MAF unless i had a speed density tune. So im considering contacting Frost about a mail order tune to hopefully get this worked out and driveable
