ls1 way too rich
That with the fact that you have open headers is going to make for a stinky stinky car.
1. O2 sensors- tuner will turn off the rear O2
2. Water temp sensor - I tapped off the computer to feed my Autometer gage...big no no. It was reading -40 degrees on a 90 degree day. You must use a seperate sensor in the passenger head.
3. MAF - needs to be plugged in and properly plummed.
4. Vacuum leaks - make sure all the extra ports are plugged.
5. Factory tune was really rich on the dyno.
The good news is my stock 2003 LS1 made 350 rwhp once tuned.
Also try holding your hand over the MAF with fingers slightly spread. My idle picked up with a little restriction.
The real problem with mine was it was not seeing the TPS because I had converted from DBW to DBC. Once we put the tune in from a 2002 TA it ran very well.
Do you have larger than stock injectors? If so, there is your problem - don't run it until you get a base tune in it or you risk washing it out. At the very least, you will foul the plugs.
The coolant temp sensor has to be hooked up - don't unhook it as directed above - that will cause it to run way rich too... IAT sensor needs to be hooked up as well...
Get it tuned.
A tuner will need to know exactly what is in the car as far as injectors, MAF, heads/cam, fuel system (including regulator) and probably a few other details...
Your other option would be to trailer it to a tuner... or get tuning software and tune it yourself...
There is a difference between "close enough to run" and spot on to the build IMO. Then again that depends on your tuning techniques.
