I need.to know where to post
Old Aug 22, 2012 | 03:49 PM
trevmust's Avatar
Default I need.to know where to post
I want to.do an ls3 swap on an el camino, but I need advice for every aspect of.the swap. From fuel system to.whether I would use amd el camino radiator or a corvette rad... Also... Does the.guy.who.owns this.forum own thirdgen.org too? the layout.is similar :p
Old Aug 22, 2012 | 03:52 PM
trevmust's Avatar
Another helpful bit.of info would be how to.put a tremec t-56 into.an elkie...
Old Aug 22, 2012 | 03:57 PM
badformulaLS1's Avatar
what's with the periods?
Old Aug 22, 2012 | 04:04 PM
trevmust's Avatar
My cellphone has a really small spacebar and the period is beside it.
Old Aug 22, 2012 | 05:21 PM
rockytopper's Avatar
Check out the stickys it will answer alot of your questions
I'll try and help with your first 3.
You can use your stock radiator or upgrade if budget permits.
You can use your stock fuel tank or upgrade to an EFI unit if budget permits.
Installing the 6 speed trans in the A-bodies requires modification to the tunnel area of the floor.
Old Aug 22, 2012 | 06:06 PM
trevmust's Avatar
I wanna get a custom tank, I need to know what fuel pump the ls3 needs to function properly. I dont plan on modifying the engine at all.
Old Aug 22, 2012 | 07:16 PM
99VetteFRC's Avatar
You didn't specify what year your cartruck is. Read through my build thread for my 70 Chevelle, should be similar if not exactly the same, other than the t56.
Old Aug 22, 2012 | 08:10 PM
trevmust's Avatar
Sorry. 1980..... Right in the middle of the a body to g body conversion that gm did for whatever reason.
Old Aug 23, 2012 | 04:47 AM
99VetteFRC's Avatar
I used to have a 79 Malibu, loved that car, but they are very similar. More so than the mid 70s a body. They are a little narrowerer under the hood and the motor mounted are a little newer but all the same intallation principles still apply I would think. I even had a 70 10 bolt than a 66 12 bolt(had to move spring perches) in my 79. All the control arm and shocks bolted right up. wheels are different offset though.
Old Aug 23, 2012 | 09:38 AM
psiconversion's Avatar
LS1Tech Sponsor
We are using a Dorman Tank and sender. I modified it to accept an intank fuel pump. Was running an LT1 but now have an LQ4. Car is an 86 El Camino.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Aug 23, 2012 | 11:08 AM
bczee's Avatar
As Rocky stated, Read over some of the past build threads and projects for your generation of car (A or G Body)..
Once you have an idea of which way you want to go.. then come back with your question, but try and keep the question to specfic area of the swap.. too large of a general Do All question gets way to many answers and suggestion to be of any real use.. just more to confuse you.
Then give us some good info about what your doing for a phase of your swap. Break it down to the engine install, fuel system and wiring... Trans, rear ends.. etc..
oh.. btw.. we like pictures.. !
BC
Old Aug 23, 2012 | 10:31 PM
trevmust's Avatar
Thanks.for.all the help.guys!
Old Aug 24, 2012 | 01:29 PM
darren roar's Avatar
if u cant find help around here youre up that one river
