Project Red Beast
Old Aug 23, 2012 | 12:14 PM
senor_camaro's Avatar
Default Project Red Beast
Picked up a rough S14 for 2000, had major problems. Build will go as follows:
1995 Nissan 240sx OBD-1 base model, equipped with Megan lowering springs,
Rota 15 inch wheels, and its auto
Upgrades scheduled for installation:
1998 Corvette LS1 with 6 speed T56 six speed.
6 piston Brembos Brakes
Rota P45r 18's
Full S15 body conversion, includes roof, quarter panels, tail, side skirts, front end, trunk, and tail lights.
custom engine mounts designed by me
Custom wiring by me
Kaaz 2way LSD
Driveshaft shop upgraded axles 700+HP
Custom diff oil cooler built by me
Oil drysump from ZR-1 Corvette
Beehive heavy duty valve springs
Custom grind cam from Comp Cams
Z06 cylinder heads
MSD ignition coil system
Forgot to mention I go to Wyotech Long Beach, this vehicle will be my entrance to drifting. Enjoy the build!
after some major R & D, i decided to rebuild the block and strengthen the bottom end
Old Aug 23, 2012 | 12:16 PM
I took the shortblock to school and disasembled the bottom end and was very dissapointed
#6 rod connecting rod bearing took a dump, must have had an head gasket/oiling issue was overreved.
Old Aug 23, 2012 | 12:26 PM
So after all this and 30 minutes of being pissed off, I decided to build an LS7 and stroke the **** out of the motor. Im leaning towardsa texas speed 7.0 kit, with that in mind I want to get atleast 427 Cubic Inches out of her. The motor almost weighs as much as the stock KA24de
I decided on this Rotating assembly
Texas Speed & Performance rotating assemblies offer the best durability with the best pricing available! Our 438 and 441 C.I.D. LS7/LSx rotating assemblies come standard with your choice of a forged Callies Compstar 4.10" or 4.125" stroke crankshaft, Texas Speed & Performance H-Beam 6.125" connecting rods with ARP 8740 rod bolts, and Mahle-8cc flat-top pistons, wrist pins, and plasma moly piston ring set. Callies offers both a 4.10" and 4.125" stroke crankshaft, which we have listed. All of the piston sets listed will work with either stroke crankshaft; The 4.10" stroke crankshaft will require a slightly shorter block deck height vs. the 4.125" in order to achieve a "zero deck" setup.
Old Aug 23, 2012 | 12:55 PM
JakeFusion's Avatar
Super Hulk Smash
Need a new block or you need to sleeve the LS1 to be able to fit pistons in there over 3.905" diameter. You can fit up to a 4.125" stroke in there, though, which would give you a 395cid engine out of the LS1.
The only problem is your ring lands would be pretty shallow. For an NA motor it's fine.
Old Aug 23, 2012 | 05:12 PM
do you think its better to invest in a LQ iron block to bore pistons out?
Old Aug 23, 2012 | 05:39 PM
Verz's Avatar
Ill keep an eye on this build, big 240 fan and seems you have ALOT planned for this one from where its currently at. Goodluck with the build.
