ls6 wont start - sensors?
thanks
If these are the first attempts to start it, after the swap, then I agree with the person above^.
If the 2002 VATS works similar to a 98/99, then I'll guess that the BCM was not carried forward to your Tahoe.
The BCM puts out a 30 or 50 cycle signal, which is detected by the ECM. Once this happens, the ECM allows fuel pulses to the injectors.
If this is the trouble, you can have the VATS function deleted from the ECM.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
As for sensors. I have the maf and O2 and the fuel pressure sensor hooked up.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
P0452 - Evap Pressure Sensor / Low Input
P0453 - Evap Pressure Sensor / High
P1125 - Acc Pedal Pos System
P1516 - Command Vs Actual TP Perf (TAC Mod)
P1518 - PCM To TAC Mod Serial Data Circuit
P1639 - 5 volt Ref 2 circuit
The pedal is attached and working the throttle body so I'm not sure why that's there. I'm thinking I got the Fuel Pressure Switch connected wrong. But these codes aren't showing the VATS code that I have seen others saying is there when scanned?
but this one doesn't make sense because it was in there twice and know it's only in there once:
So, I guess the 5 volt ref 2 circuit is the problem. I'm not sure where the wire goes. I can't find a 5 volt to connect it to???
