Quick question about oiling a stored motor
Old Aug 27, 2012 | 10:08 PM
AustinYukon's Avatar
Default Quick question about oiling a stored motor
I've got an '04 LS1 that's been sitting in my car for a couple of years. I want to dump some oil down the cylinders and turn the crank over before winter again.
Do I just squirt 1/4 a quart down each plug hole and crank her over?
Old Aug 27, 2012 | 10:35 PM
1970's Avatar
WOW, 1/2 a quart?
Depends on where each piston is!
Some must be near top-dead-center...
Old Aug 27, 2012 | 10:37 PM
Originally Posted by 1970
WOW, 1/2 a quart?
Yeah I'm an idiot and half asleep. I edited it.
Old Aug 27, 2012 | 10:58 PM
mdrn69velle's Avatar
I think even 1/4qt is too much. unless you let sit there for a week or so, so the piston soaks all around the rings then somehow get it out. I wouldn't start it with 1/4qt over each piston.
Old Aug 28, 2012 | 12:39 AM
bczee's Avatar
I would have used Marval Oil.. I would let that soak for a few days, it should soak down past the rings. They squirt maybe a table spoon of motor oil and then hand turn it over a few times.. then try starting it up.
If you have to much oil, you could hydro lock the engine. If you still have that much oil in there, I would take the spark plug out and crank it over, hoping the compression would spit out the excessive oil through the plug holes.
BC
Old Aug 28, 2012 | 08:27 AM
91sonomast's Avatar
Why not just start it and let it run?
Old Aug 28, 2012 | 09:22 AM
Pop N Wood's Avatar
You could pull the plugs and squirt a teaspoon or so of marvel mystery oil into each cylinder.
Best option would just be pulling the plugs and cranking it over for 10 seconds at a time until you read oil pressure. That will lube everything up. Oil collects water when sitting, so changing out the oil before you do that isn't a bad option.
Old Aug 28, 2012 | 09:58 AM
Thanks guys, I will buy some Marvel.
There is no intake, starter or wiring harness yet so I can't fire it up.
