86 Notch lsx 402
Old 08-31-2012, 06:23 PM
racerrit's Avatar
Default 86 Notch lsx 402
Well decided to make a new thread. Cage is in, motor is almost done (ls2 with 4.0 stroke callies crank manley pistons n rods, comp custom grind cam, l92 heads with manley springs decked .30, edelbrock vic jr with an 850 quick fuel carb n a plate with 200 shot. Would b finished but cam bearings were installed wrong so gettin them redone tommorow. Trans is finished, level 7 RPM 4l65e with a coan 3600 stahl. Has a Broke Dick racing cage, with skinnykid motorplate, n aje k member n a arms. Upr Anti rollbar and front coilover. Lakewood Dragstruts n comp rear shocks with granetelli upper n lower control arms. 35 spline spool with polished ford racing 4.10s n moser axles. rear is narrowed 1 in per side to allow the 28x10 drag radials. If all goes well i hope to b at Indy NMCA. She will still look ruff but ill get er painted this winter. Gonna run True street n Rumble!
Attached Thumbnails 86 Notch lsx 402-529879_393793620654475_100000715215910_1262917_1732539435_n.jpg   86 Notch lsx 402-538614_433779436655893_473460841_n.jpg   86 Notch lsx 402-542394_432005393499964_181812657_n.jpg   86 Notch lsx 402-599447_433779329989237_586166059_n.jpg   86 Notch lsx 402-574706_393793257321178_100000715215910_1262916_184668681_n.jpg
Quick Reply: 86 Notch lsx 402
